VAC #
Ron
09-16-2003 19:33:12
I just bought a 1950 VAC5452074 the question I have is, I found a number stamped on the right hand side of the block, 72 with about 1/2in. gap then 022197. Is this to say it is not the block that it came out with. Where would I look for how many of these tractors were make in 1950.
Joe (Wa)
09-16-2003 21:53:08
 Re: VAC # in reply to Ron , 09-16-2003 19:33:12
Hi Ron, My VAC manual states that the nr 72 indicates that this is a VTA-1072 engine assembly built at Rock Island.
The manual further states: "Because of the fact engines are manufactured at Rock Island for other machines such as combines and because of the need for replacement assemblies as repair items, there is no definite relation between engine serial number and tractor serial number". (Dang, my typing finger just went numb) Joe
F-I-T
09-16-2003 19:57:46
third party image
Ron:
I bought #5459267, also a '50, so it appears there were at least 9267 of 'em.
Can't answer your question on the block number, as I'm still learning J.I. Case specifics myself.
Frank-in-Tallahassee
70D // 855 // VAC
Lew
09-16-2003 21:32:26
 Re: Re: VAC # in reply to F-I-T, 09-16-2003 19:57:46
From the picture it appears it ought to "bark" pretty good the way the exhaust manifold looks. Did you remove the elbow or did it come it with no elbow? Someday I am going to attempt to remove the elbow from my 51. In the winter, I want to reroute the pipe to go closer to the carb to reduce the icing we get here in Wisconsin on our wet cold winter days.
F-I-T
09-16-2003 22:50:52
 Re: Re: Re: VAC # in reply to Lew, 09-16-2003 21:32:26
third party image
Lew:
That's as I found it. I've since got a different manifold with elbow, and the whole thing is currently strippped down to it's skivvies, getting a valve job, head truing, rings, rod bearings, seals, and paint. Anything that will fit into my electrolysis tank is getting stripped and de-rusted before priming. Put a bit of color on the engine as a test. It's a DuPont code, but I think it's a tad off, so I'll use the PPG code. It seems to be right on with the paint I have found as original. I'll use the DuPont up as the first coat or two.
Frank
