Case SC brakes
Joel Shelton
09-16-2003 15:19:23
I just got a 1950 case sc and the brakes were not working at all. I took apart the brakes and found that it looks like there are a couple of parts missing. I think I am missing one spring that is attached with a key that is attached to the pad with a groove in it. also I cannot find any bearings or springs at all in the assembly. So far what I have taken off is the acuator rod, gearing for adjustment, the plate with the grove in it, the brake shoe with the gear that goes inside the tractors transmission gear and that is it. Are the brake bearings inside closer to the transmission housing or in the brake assembly? Sorry this is so confusing. I went to a case dealership with the parts today and they did not have a clue. Does anyone have a photo of their brakes broken down or a copy of what the the diagrams of how the brake acutally breaks down. I took both brake housings off and it is the same on both sides. Neither brake has worked since I got the tractor a month ago. Sorry this is confusing. I will see if I can post a picture of it later. Thanks
Joel
dctom
09-17-2003 10:11:25
 Re: Case SC brakes in reply to Joel Shelton, 09-16-2003 15:19:23
joel your tractor was built jan 4 1950 and shipped to culpepper, vir, jan 26 1950 with all the advice you have here your braks should work just fine lol DCTOM
C. Amick
09-17-2003 09:15:06
I have rebuilt around 4 sets of these brakes now. I order grade 220-C stainless steel balls from the McMaster Carr Company. They have a web site. The sizes you need are 3/8" and 1/2". I think there are 3 - 3/8" balls and 5 - 1/2" balls, if I remember correctly. I went to NAPA and got a generic automotive drum brake kit that had a bunch of miscellaneous springs and other parts in it. Some of the pices had to be modified a little to make them work. I get my discs re-lined locally. Hope this helps.
Baggsy
09-16-2003 17:47:51
Joel, Brakes are a nice thing to have...I didn't find out mine were bad until I removed a loader and moved it into the shop for the first time. I missed the wall by less than a foot! It was like stepping in a bucket of mud. Nothing! Led to an anxious moment or three.
I believe in '52 the S series went to a double disc brake, and they are a pain if I remember right. The brakes on yours should be single disc, and are adjusted by jacking up the tire, loosening the three cap screws, and tightening the adjusting pinion until drag is felt when spinning the wheel. Then back it off a turn or so. If you bottom out the pinion and the actuator is fully depressed, new linings are in order. Schotte should have the part numbers you need, but they are $70 @ last time I checked with Case. There is no spring. The pinion spins a ring which adjusts the contact clearance of the brakes. Pretty simple really. If grease is leaking into the housing, there is a seal on the back side of the housing that needs replaced but the rear end must be drained to do this (it makes a heckuva mess if you don't, I tried). Write back if you still have problems. In the meantime, fashion a quick release anchor...(grin)
Joel Shelton
09-16-2003 17:53:52
 Re: Re: Case SC brakes in reply to Baggsy, 09-16-2003 17:47:51
Thanks Baggsy for the reply. I don't guess I have that many parts missing since you say there are no bearings in the brake system I should be good. I have some parts coming from Don L so I should have extras just in case. What or where is Schotte?
thanks
Joel
Mike Schotte
09-16-2003 20:22:43
 Re: Re: Re: Case SC brakes in reply to Joel Shelton, 09-16-2003 17:53:52
O.K. guys- sorry I missed the fun. Gotta be up at the crack of dawn tomorrow morning to watch them drill 24 piers for a bank I'm working on.
Got the early, middle and late SC parts manuals right here-
There appear to have been 3 types used on the SC over the years of production.
According to "Full Steam Ahead"- the brakes changed from a "Case type to a Bendix type" at Tractor No. 4504858 (1941 production.)
I can't find anything anywhere that tells me when they then switched to the last style of brakes... but I think it happened the same year as the Eagle Hitch made it onto the SC ('50 or '51??)
The 1941 manual and the middle year manual call them "independent" brakes (although at first glance they appear to have different part numbers.)
The later parts manual has the breakdown for the last style of "differential" brake.
LOTS AND LOTS of individual part numbers. Can you narrow it down and give me an idea of which things are you looking for? Linings and seals only?
I haven't worked on my brakes yet- Myron Amick (and Baggsy) are your men for "how-to" advice.
-Schotte
John Saeli
09-17-2003 04:26:30
 Re: Re: Re: Re: Case SC brakes in reply to Mike Schotte, 09-16-2003 20:22:43
Hey Mike! Bank construction!! That sounds like a winner. Buddy, Pal, Ole friend, we might be cousins. BTW, you do have the combination to the vault, right??
Joel Shelton
09-16-2003 20:58:35
Mike, I believe, looking at a very bad photocopy of a manuel from the case dealer, that the parts I am missing is 07210ab(ball), 5659 (disc), misc ball bearings and inserts as well as pins, one spring 05890ab and pin. Sorry but this is all I have, basically it is the middle of the brake. By looking at this and the parts I have, i do not have any ball bearings and so forth. My tractor is a 1950 so it has the single independent brake as the serial # is 5405424sc.
Thanks
Joel
dctom
09-17-2003 07:54:16
 Re: Re: Re: Re: Re: Case SC brakes in reply to Joel Shelton, 09-16-2003 20:58:35
JOEL- THOES BREAKS ARE VERY SIMPLE, WHAT YOU TAKE OUT WITH THE OUT SIDE CASTING IS THE ACTUATOR (SP) THERE SHOULD BE THREE SPRINGS THAT HOLD IT TO GEATHER AND IN SIDE ARE THREE BALLS ABOUT 5/8 IN. YOU HAVE TO CLEAN THE RAMPS THESE BALLS ARE IN AND MAYBE NEW BALLS, THAN MAKE SURE THE LILNNING DISK IS FREE TO MOVE ON THE SPLINE AND MAYBE NEW LINNINGS, SEALS IF THERE IS GREASE OR OIL ON THEM, DCTOM, WILL SEND BUILD CARD INFO LATER HAVE LOTS OF OTHERS TO DO FIRST TOM
Baggsy-Wy
09-16-2003 19:47:48
Mike Schotte...professional Case tire changer and carb tuner! He's usually around out here, I'll shoot him an e-mail, he may be busy taking tests.
I'd sure get a set of manuals if you can. The operators and maintenance manual are good from Case and will help you a bunch. The IT manual has it but is a bit more vague in it's illustrations. Money well spent I would say. Don L will get you just what you need. Great guy to work with on parts. Just whisper his name in your tractors ear and it'll respond...
