Case VAC Hydraulic problem
Sodbuster - Mar
09-16-2003 14:33:17
I am trying to help a friend with a VAC case with an eagle hitch, and he's having a hydraulic problem. The blade lifts up and down okay when running however, when I stand on the blade it only lifts if you run the throttle wide open. We changed the fluid and it turns white color and foamy. Any suggestions?
Joe (Wa)
09-16-2003 15:37:22
 Re: Case VAC Hydraulic problem in reply to Sodbuster - Mark, 09-16-2003 14:33:17
Sounds like you're sucking air on the pump inlet side. Check the tube for punctures. If the tube nuts on the pump and torque tube are already tight the likely problem is the ferrule under the torque tube nut. If you can turn it on the tube with your fingers, it won't seal. Check the pickup tube under the ferrule for fracture. Clean the breather also while you're there. Joe
