belt pulley removal on VAC
gerald
09-16-2003 10:15:28
Anyone know the best way to remove the belt pully on a VAC. I have a 49 with a hydraulic pump as part of the belt pulley assembly. I have a pretty good leak there and can't get at the pump with the belt pulley in the way. Help! I do not have a manual for this tractor. Thanks in advance. Gerald.
wheat straw
09-17-2003 05:52:13
 Re: belt pulley removal on VAC in reply to gerald, 09-16-2003 10:15:28
gerald,
If you are driving it just remove the nut, throw it in the tool box and drive the tractor. It may take 20 minutes or ot may take till dinner, but it will just hop right off for you. easiest way I kno9w and have never harmed the pully,
wheat straw
C. Amick
09-16-2003 14:16:16
The belt pulley is held on by the nut that is in the center. You should be able slide it off after you get the nut off.
Gerald A. Kern
09-16-2003 15:09:43
 Re: Re: belt pulley removal on VAC in reply to C. Amick, 09-16-2003 14:16:16
I tried getting it off, half-heartedly one day. Took off nut and actually "gerry-rigged" a wheel puller with a chain and a small hydraulic jack. It would not budge, with some pressure. Thought I'd better not force things, since I did not know what all was involved. Is it a tapered and keyed shaft? Do you know anything about the pump? It seems to be leaking fluid unto the pulley and the pulley in beginning to throw fluid? There are two bolts on the pump part and one in not accessible to tighten with the pulley on. Are there gaskets that can be replaced there? Thanks for your help. gerald
C. Amick
09-17-2003 05:17:59
 Re: Re: Re: belt pulley removal on VAC in reply to Gerald A. Kern, 09-16-2003 15:09:43
Yes, it is a tapered shaft with a half moon key in it. There is a seal around the shaft that you can probably find a replacement for. I believe the housing that is behind the pulley has to be removed in order to get to it. You might try spraying it with P.B Blaster and leaving the nut off. May be it will work itself loose.
gerald
09-17-2003 05:30:57
 Re: Re: Re: Re: belt pulley removal on VAC in reply to C. Amick, 09-17-2003 05:17:59
Thanks for the information and suggestions. I've never used PB Blaster, but have seen it mentioned a number of times on this site. Will get some.Is it readily available? By-the-way, just used JB weld to coat the inside of the hydraulic cylinder on the other side of the tractor that was badly pitted. Used a homemade tool just a bit smaller than inside diameter of the tube to spread it and to sand it. Put it back on yesterday, and so far no leaks and it seems to work fine--will see.
C. Amick
09-17-2003 05:37:32
 Re: Re: Re: Re: Re: belt pulley removal on VAC in reply to gerald, 09-17-2003 05:30:57
P.B. Blaster is available at most auto parts stores. It works better than anything else that I have ever used. J.B weld is also a very good product. I hope it will hold for you. The last time I checked, those internal leather cups for the hydraulic cylinder are still available from the dealer, should you need one. Some people just use rubber brake cups instead.
