Sickle Bar Mower Instruction help needed
Paul f
09-15-2003 14:48:09
I recently obtained a Case Eagle hitch sickle bar mower (7ft bar). I also scrounged up a parts manual for the EH 7 series mowers. While many of the casting numbers are the same there are some design differences between my mower and the parts manual. The lifting bail spring is mounted to the left (as you look a mower from tractor) the EH 7 series seem to be on the right side. The release latch spring mounts on the top (parts manual looks like it mounts underneath.
The mower works but the trip release accuates frequently even though I have the bar fairly high and am going slowly. Also it is very hard to get the bar parallel to the ground. What I need is an ID on the mower (I can't find a data plate and):
Does anyone have an instruction manual for sale (or rent so i can make some copies?????
This is my first sickle bar and the neighbors all use haybines or disc cutters (the old guys used trail mowers not 3pt/eagle hitch types)
Thanks Paul f
