LA and 500 rearends
JD PULLER
09-15-2003 11:13:02
allthough I normaly pull John Deeres I am thinking about building one really hot LA case for pulling the problem comes with the idea of the chain driven rearends. Is the 500 this way also and if not what would I have to change to put the 500 rear end on an LA?
dctom
09-15-2003 15:21:21
 Re: LA and 500 rearends in reply to JD PULLER, 09-15-2003 11:13:02
JD-- I WOULDNT WORRY ABOUT THE CHAIN DRIVE, IT IS THE MOST EFFECIENT WAY TO TRANSFER POWER, I KNOW YOU PROBLEY HAVE HEARD ABOUT BRAKING CHAINS BUT MOST OF THE TIME THE COTTER PINS COME OUT AND THAN THE SIDE LINK COMES OFF AND THE CHAIN JUST COMES APART, THERE IS SOME PRETTY HOT LA'S AROUND I KNOW OF SOME PRETTY HOT DC'S AND THEY ARE ALL CHAIN DRIVE JUST MY TOO SENTS DCTOM
CASE1979
09-18-2003 13:09:43
 Re: Re: LA and 500 rearends in reply to dctom, 09-15-2003 15:21:21
Hey dctom I was reading some of your comments and came across some interesting news that you have the build cards for DC & SC models I have some serial#'s I was wandering if you could look them up for me.521352sc, 5316021dc, 5504207dc, D430399839. I also know that the L to the 500 are the same chain(140) and axle Dia. but from the 600,900,and early 930 wheatland models they used (160) chain and axle Dia.
caseman-d
09-15-2003 11:24:14
Both tractors have the chain drive, Case used the chain drive up to the mid 60's. Don't quote me but I was thinking they quit the chain drive with the Comfort king models.
caseman-d
Jim P
09-15-2003 21:54:03
 Re: Re: LA and 500 rearends in reply to caseman-d, 09-15-2003 11:24:14
The 930 Comfort Kings came chain only 64 and both ways (chain and gear ) 1965 and 1966 and 67 on were gear only. Correct me if I'm wrong. Also did the comfort king come out in 63 or 64?
Jerry
09-15-2003 17:45:08
Caseman-d
I believe that the case 400 was the first non chain drive in 1955. Help me out on this one guys.
It was their new tractor design and make over.
caseman-d
09-19-2003 12:02:00
 Re: Re: Re: LA and 500 rearends in reply to Jerry, 09-15-2003 17:45:08
I thought the first 400's had a chain drive and then when they went to the B series was when they switched from chain to gears. I'm not sure on this?? Maybe it was the standards that kept the chain drive.
caseman-d
dctom
09-15-2003 18:16:19
first big tractor yes, the v-va were gear drive dctom
