Tie rod ends apart?
G. L. Perry
09-14-2003 19:37:17
Case SC. Tied rod ends have the screw out plugs in end. I have pins out, tried tapping with punch and hammer. Not moving. Is there a special tool to unscrew them? Have to remove the grease zerk to use it? Anyone ever make one from a socket and have it not break the tabs? Suggestions?
Klyde
09-15-2003 09:32:13
 Re: Tie rod ends apart? in reply to G. L. Perry, 09-14-2003 19:37:17
take out the zerk and use a drag link socket. (used to come in socket sets) or bend a length of band iron and use that.
F-I-T
09-15-2003 05:26:38
G.L.:
I just removed those threaded caps from my VAC, and I used a slice from a piece of 1/8" angle iron, about 1/2" x 1" and gripped it tightly in the jaws of some vice grips. Then I used a crescent wrench to grab and turn the vice grips.
I removed the grease fitting first, then I warmed the area up with just a propane torch. The old grease was pretty stiff in those threads. It took a pretty good force, but when it began to move it walked right out
Frank-in-Tallahassee
70D // 855 // VAC
