300/400B engines
Terrance
09-13-2003 17:03:12
Terrance,on 10/24/1961 Case issuded a service bulletin to its dealers.subject,short block assemblies.No.G10502 fits 300,300B,310 wheel tractor and 310,310B,310C crawler tractor. No.G10504 fits the 400B only. The starter on a 400B goes through the rear flange on the block,the 300 starter bolt against the torque tub/bellhousing.Check out the two lower bolt holes on the rear flange of the engine and let me know what you find. martin
Martin
09-14-2003 11:25:07
 Re: 300/400B engines in reply to Terrance, 09-13-2003 17:03:12
Martin,I stand corrected, there is a considerable difference in the bolt spacing between the 400B and the 300/300B block bottom bolt holes. Thank you for bringing it to my attention, I definately do not want to be passing out bad information here.
Thank You Terrance
