Could I have a case ?
Jimmy
09-12-2003 18:43:09
Someone gave me an old Road grader of some type. It is yellow with a red engine. It has a 9 ft blade underneath between tires. It looks a lot like a tractor. The cab has a door that opens from the rear. I beleive it has a Hercules engine? Any thoughts on what this is? Thank you.
Dan in Ore
09-13-2003 00:48:21
 Re: Could I have a case ? in reply to Jimmy, 09-12-2003 18:43:09
Can you find any serial numbers on this item?
If it is Case, then "Old Abe" the Case eagle will be cast into most of the castings.
A pic would help.
Dan
