VAC Project: Pushrod question
F-I-T
09-12-2003 10:25:45
My 1950 VAC has one slightly bent pushrod. While buying some other parts, I asked the seller to send me a good pushrod. The one he sent is smaller in diameter than the ones I have. I wasn't aware that Case might have used two different diameters. Is it a problem to use the smaller diameter pushrod, or should I look for a larger diameter one.
Thanks for your thoughts !
Frank-in-Tallahassee
70D // 855 // VAC
Joe (Wa)
09-12-2003 23:35:26
 Re: VAC Project: Pushrod question in reply to F-I-T, 09-12-2003 10:25:45
Hi Frank, Yeah I ran into the same thing, bought a rocker asm and the thinner pushrods were thrown in. I have a 53 VAC and got the later rod from Case on line. New nr is A30259 about $20 ea. Joe
Joe...do you have an addr
09-13-2003 05:43:43
 Re: Re: VAC Project: Pushrod question in reply to Joe (Wa), 09-12-2003 23:35:26
Joe:
Thanks for the reply. You bring up an interesting question for me. You said "Case online".... I'm familiar with JDParts.com for my JD needs, but would really be interested in knowing the address so I can sign up. Since I have no dealer nearby (the closest is 70 miles and they didn't know Case built a VAC...) online purchasing would be a big plus for me. I have an older parts book (R.I. D61) so I hope I can cross those numbers.
I'll do some surfing, but if anyone can help me out with an address, I'd sure appreciative it.
70D // 855 // VAC
F-I-T...Joe, one more thi
09-13-2003 12:47:54
 Re: Re: Re: Re: VAC Project: Pushrod question in reply to Joe (Wa), 09-13-2003 09:18:12
Joe:
Yup, Tallahassee is the capital city of Florida.
One other question. I have this old parts book. Can I get a newer one that has "new" part numbers? Or maybe a parts CD (I have one for my Deere stuff). I tried searching some of the old "VT" numbers but they come back as an error.
Thanks again !
Frank
F-I-T
09-13-2003 17:09:55
 Re: Re: Re: Re: Re: Re: VAC Project: Pushrod ques in reply to Joe (Wa), 09-13-2003 15:48:54
Thank you, Joe !
Now I can do my own research ! This will be very helpful !
Frank
C. Amick
09-12-2003 10:50:04
The thinner diameter push rod is probably an older one. I usually just straighten the bent ones and use them. The thicker one should work as well.
