Zenith carb for Case model SO
John Stettler
05-09-1999 21:04:49
After I installed a new needle valve in the model 161JX7 carb to stop fuel dripping, the engine backfires, sends up big puffs of smoke, has no power, and won't run except at idle. Also tends to stall unless I keep some choke on. The only spec I have says set the top of the float, when held upsidedown, 1 & 5/32 inches from the casting surface. Isn't there know a more accurate way to set fuel level -- like fuel level in the lower casting relative to the top edge of the lower casting. Seems like there's way too much fuel getting to the cylinders.
