DI?
John(AZ)
09-11-2003 22:58:42
I have a tractor that I thought was a LAI but the tag was missing. I've since found out that I could locate the serial number on the left side of the clutch housing. I got out tonight and scraped away 50 yrs of dirt and paint and located a number stamped in the engine block right where it bolts up to the clutch housing on the left side of the tractor. The Number is 5215968DI, The D is a bit irregular and I'm assuming it is a D.
Now if I'm correct this should be a 48 DI tractor.
Please correct me if I'm wrong!
I'd like to know the weight of the tractor, engine size, horse power ratings and anything else anyone wants to share.
this tractor has a 3 speed transmission and top speed seems to be around 2-3 mph. All I know for sure is that it took hours, or so it felt, to drive it home (about 2 miles). I'm used to my farmall H that will run around 20mph.
Mike Schotte
09-12-2003 04:06:56
 Re: DI? in reply to John(AZ), 09-11-2003 22:58:42
John,
Does this look like what you've got? This is a DI model (although I've never seen one with fenders like this before) I had a blast driving this guy for Bruce Nelson at the Almelund parade.
third party image
Attached is a link to a post where I gave the weights.
You seem to be missing a gear- a DI should be a 4-speed. Your tractor is a 1948 model... so it's not early enough to be a converted CI model.
First gear: 1.88 mph
Second: 3.62 mph
Third: 4.98 mph
Fourth: 10.1 mph
Reverse: 2.84 mph
Hope this helps,
-Schotte
Sam Cooper
09-26-2003 19:01:25
 Re: Re: DI? in reply to Mike Schotte, 09-12-2003 04:06:56
Hi Case lovers! I was born & raised on a farm & we used every brand tractor other than Case. I've
restored many old tractors. I've now bought an old
Case DINT in good shape. However, the rad. leaks pretty badly & it overheats rather quickly. Upon
a closer look, I see that it has NO water pump. Was this kosher for a 1951 Case DI? This tractor is 95% original. It looks just like your photo, except the fenders? Did DINT's ever have fenders?
Sure could use some info about my new find!
