4890 Case tractor oil pan help
Curt Cooke
09-10-2003 06:33:06
Friend of mine has a 4890 Case tractor (this thing is huge) in need of a baffle in the oil pan. Where would one start to look for such a thing. Since the fellow works at a Case IH dealer, I assume that such an item is no longer available. Thanks.
Curt
or call Dave at 616-299-3750
Shane
09-10-2003 17:07:40
 Re: 4890 Case tractor oil pan help in reply to Curt Cooke, 09-10-2003 06:33:06
From your area code I see you are in MI. Not too far from me. Might try Worthington Ag Parts. Not sure where you are in MI but they are only 40 miles from South Bend,IN. They are nationwide too and should be able to get one. Good luck.
Jim Handke
09-10-2003 14:06:39
try [email protected]
Glen in TX
09-10-2003 08:59:25
Check with some of your local salvage yards and if that fails they can probably find it with their locator service. That is how we found a rear end for a 4890. Good luck.
