Hi John, No one was there to talk to, so here's what I could see: S/N 6081105, 1239 hrs - but doubt that's real. Both front axle bolsters had been strapped and welded, but done well. Front tires were good. Front grille gone, steering punkin leaks badly, air filter cannister was all beat up. Side hood panels gone, but rest of tin looked pretty good. Original paint was pretty faded and all surface rust. Instrument cluster looked real good. Brakes both had resistance. 1 rear tire badly checked and little tread, but would probably go a while, other tire was fine. Must be loaded (13.9x36), could still see fluid on ground where someone had tested valve stem. One rim had been repaired, valve stem hole moved - done pretty well. All the eagle hitch parts appeared to be there. Inside yoke housing where front of arm attaches to diff was poorly welded on one side. Had two remotes, triple range - operators platform looked pretty good other than inside brake pedal "ear" broken where latch catches. I think it is a little overpriced at $2,200 (OBO the sign says). But if this model is as rare as I think - maybe it is worth it? Contact is Joan - 607-898-3959 from 8-6, or 607-844-4224 nights at home. Let me know how you make out, or if you have any more questions. Good luck! Tim
