Oil and service tasks on Case SC
Joel Shelton
09-09-2003 20:37:39
While I am waiting for my owners manuel to get here from ebay, I have a couple of questions about the service on my 1950 Case SC3. First of all, where do you check the engine oil? Next were do you put the engine oil? There is a opening with a cap next to the maginto, is that were it goes? What kind of battery box did the Case SC have? What type of engine oil would you recommend? Finally, How do you drain the oil? By the 2 plugs on the oil pan I assume.
Thanks
Joel
Baggsy-Wy
09-09-2003 21:06:44
 Re: Oil and service tasks on Case SC in reply to Joel Shelton, 09-09-2003 20:37:39
Check oil on the right side of oil pan, two plugs, high and low level. Fill till it just starts coming out of the high one. Fill up by magneto (crankcase filler opening). Drain on bottom of oil pan, plus drain clutch housing (below belt pulley-square head plug above draw bar bracket). Drain oil filter housing and replace filter. Replace oil in oil bath air cleaner. Scrub your oil pump screen (left side of oil pan, three bolts holding). Oil with whatever is best for your machine. If it hasn't ever had detergent oil in it, run non-detergent. If it has, run what you feel the most comfortable with. I run 10W-30 year round, but some prefer straight weights, lighter in winter, heavy in summer. The battery box was a slide out tray that are hard to come-by now...
Joel Shelton
09-09-2003 21:29:02
 Re: Re: Oil and service tasks on Case SC in reply to Baggsy-Wy, 09-09-2003 21:06:44
Thanks for the help.
jal-SD
09-10-2003 06:51:36
 Re: Re: Re: Oil and service tasks on Case SC in reply to Joel Shelton, 09-09-2003 21:29:02
Call Don L in Austin, Mn (507) 433-0073 (AM best), or e-mail him at [email protected]. He might have a complete battery box for an SC. I picked up one for a DC this summer, but didn't ask about one for an SC. (They are not cheap.) Don is a great guy to deal with & has lots of old, NOS & repo parts for Case tractors. (My $0.02 worth. jal-SD)
