Hydraulic cylinder on VAC
gerald kern
09-09-2003 14:11:25
My VAC (49) has a small hydraulic cylinder. Inside it has a cupped leather gasket- seal that precedes the metal plunger like the type used to find in hand tire pumps. The cylinder in 1 1/2" in diameter. I was very surprised to see something like this. Anyone know the "animal" I'm talking about? I don't know if this is an original cylinder or aftermarket The leather "gasket" is shot. Anyone know of a place to get a replacement gasket-seal or even a replacement cylinder? Appreciate your help
Bill
09-09-2003 18:24:30
 Re: Hydraulic cylinder on VAC in reply to gerald kern, 09-09-2003 14:11:25
Gerald, You can buy them from case. but I saved some moeny and went to a napa and had them pull out the wheel cylinder cup misc box and bought a few cups of that size. they work great. Bill
gerald
09-09-2003 19:25:21
 Re: Re: Hydraulic cylinder on VAC in reply to Bill, 09-09-2003 18:24:30
Bill, thanks for the tip. Sounds like a winner to me. Would you happen to know, what kind of load limits are on this hydraulic system? I'm putting a 6 foot sno blade on the tractor and it weighs 270 lbs. The tractor had a 2 bottom plow with it when I bought it and was used with a cultivator--so assume those loads would have been comparable.
Bill
09-10-2003 17:23:08
 Re: Re: Re: Hydraulic cylinder on VAC in reply to gerald, 09-09-2003 19:25:21
I dont know what the load limits are on the vac.
Lew
09-09-2003 21:21:26
It sounds like you are talking about the eagle hitch piston. I use a 7 foot blade with no problem. I also have a boom that works on the hitch and have lifted a 400 pound engine but was unable to pick up a 900 pound bale of hay with 70 pounds forks on the hitch. There is no down pressure on the blade so the adjustment of the top link to get a good blade angle is important for efficient snow plowing or grading. I used an old pallet with some 2x6's to make a platform to carry stuff on. Works great so I built a box to put on it and it works even better. However, I can put enough wood in the box that the hitch will not pick it up. Have fun.
