Case 885 David Brown Clutch Adjustment
bill
09-09-2003 11:35:34
Can Someone tell me how to adjust the clutch on my Case 885 David Brown. I have taken the plate off the bottom, but do not see the adjustment bolts.
Willem Botha
02-06-2006 08:19:48
 Re: Case 885 David Brown Clutch Adjustment in reply to bill, 09-09-2003 11:35:34
I HAVE A DAVID BROWN 885 ENGINE ON MY ELECTRIC GENERATOR UNFORTUNATELY THE TIMING SEEMS TO BE OUT AND DONT HAVE THE MANUAL CAN YOU HELP?
Eddie in KY
09-09-2003 21:17:13
thats how to adjust the pto clutch, adjusting the drive clutch is totally different. Elmer has the manuals, its a great investment for a do it yourselfer
bill
09-10-2003 08:18:45
 Re: Re: Case 885 David Brown Clutch Adjustment in reply to Eddie in KY, 09-09-2003 21:17:13
ok, how is the drive clutch adjusted? Which manual do you reccomend. The tech or the service?? They are very pricey. I have the diesel. It is a great tractor! I considered taking up some adjustment at the pedal by moving the pivot on the splines. The pto adjustment info was great.
Elmer
09-10-2003 15:35:44
 Re: Re: Re: Case 885 David Brown Clutch Adjustment in reply to bill, 09-10-2003 08:18:45
I can provide you with copies of the original David Brown manuals. email me at [email protected]
Elmer
09-09-2003 15:09:19
Turn the flywheel and look between the release levers. There is a allen set screww with a jam nut. Loosen the nut and bottom the screw all the way in and back it out exactly two turns. Adjust the pedal stop so you have at least one inch of free travel.
