Unknown Case Steam Tractor
Loren
09-08-2003 22:38:49
I have only the front boiler casting of my grandfather's Case Steam tractor. I know from my father that the tractor was purchased circa 1912 and was operated until 1928. Unfortunately the tractor was parted out on our farm but I would like to find out what the model was and any other info available.
The casting is the front door of the boiler with the eagle "ABE" and "CASE" below the eagle on the globe.
There is a part no. 1316C on the bottom portion of the cover.
Thanks for your help.
Glenn
09-11-2003 18:54:46
 Re: Unknown Case Steam Tractor in reply to Loren, 09-08-2003 22:38:49
1316C good for 75hp and 80hp boiler
Glenn/Mn
09-09-2003 06:10:24
I will need to know more on the engine, if you have parted this out and there are parts available for salvage they are worth somthing, the casting you gave is the same for many engines, if you can give me the size of the rear wheels or the boiler dimensions like the fire box area and number of tubes I should be able to help you more or a casting number from a pulley or fly wheel or engine frame
