Year of tractor?
rick
05-08-1999 13:49:11
I found a case tractor, but can not find any numbers where they mormal are( dash plate or engine flange). I have located this number VAC124-38267 on the top of the block above the starter.the tractor has 11x24 rears, and5.00x15 fronts. Can anyone tell the year from this number? Thanks Rick
Jeff King
05-09-1999 19:41:01
 Re: year of tractor? in reply to rick, 05-08-1999 13:49:11
First impression is that you have a 1934 vintage Case. However, check WWW.sckans.edu/~alan/tractsn.html for actual serial # range info. If I got this address wrong, e-mail me at [email protected] and I'll try again.
Jeff
Rick
05-10-1999 02:48:41
 Re: Re: year of tractor? in reply to Jeff King, 05-09-1999 19:41:01
Thanks Jeff, but did'nt the VA Series start late in 41? This tractor has the appearance of a vac. It has wide fixed front end ,and the vac grill. The only tin i have is the left side curtian (sitting on the tractor), and it has the tool boxslider in it.It also has distributor ignition.Any thoughts on where to look for other things that might help I.D. ? Thanks Rick
Jeff King
05-10-1999 20:59:16
 Re: Re: Re: year of tractor? in reply to Rick, 05-10-1999 02:48:41
I'm not a Case collector buff, just have an old 310 that I use. The serial # reference page seemed to do a good job of explaining the different variations in #'ing, is why I forwarded it to you.
Best Luck
Jeff King
