SC Case
LeRoy
09-07-2003 07:07:21
I have a SC ser. # 5319142 which my father bought new in 1949. If DC-Tom would be so kind to share a little build information,would be greatly appreciated.
Have a Zenith carburetor question, the brass tag has #11544B which I think is for an A-C tractor.
The jet behind the load adjustment screw is # 29 the other jet which I guess is for the idle is # 13. The venturi # is 19 or 61 which ever way you look at it. Would any one know if these are the correct jets and venturi?
Thanks again for any help.
dctom
09-08-2003 07:37:18
 Re: SC Case in reply to LeRoy, 09-07-2003 07:07:21
LeRoy: 5319142 SC was built april 29 1949and shipped to j i case co sioux falls S D may 9 1940 DCTOM
Coy Tite
04-10-2004 18:11:53
 Re: Re: SC Case in reply to dctom, 09-08-2003 07:37:18
Dctom, Hi I just purchased a Case Sc from a guy and I can't find out what year it was built. The Serial # 5619593. Thought maybe you could help me out. Thank's Coy
LeRoy
09-08-2003 09:23:50
Thank you very much for your time. Appricate it very much.
Thanks again DCTom
LeRoy
Mike Schotte
09-07-2003 11:28:35
Hi LeRoy,
I've got a 1949 SC also. Mine is Tractor No. #5328412SC.
The Zenith carburetor is Case part #05771AB (Zenith #9667A)
third party image
Venturis and jets are no longer available from Zenith- but according to the parts catalog... here's what they were numbered:
Venturi, main - No. 18
Jet, main - No. 30
Jet, idling - No. 16
Jet, main discharge - No. 50
Hope this helps, -Schotte
09-08-2003 20:54:13
 Re: Re: SC Case in reply to Mike Schotte, 09-07-2003 11:28:35
If I was to lay my carburetor on the carpet to take a picture of it my wife would hit me with it!
Mike Schotte
09-09-2003 06:24:45
 Re: Re: Re: SC Case in reply to [email protected], 09-08-2003 20:54:13
That was the carpet at WORK, and that carburetor was clean enough to eat off of at the time!
The manifold had just come out of electrolysis and was mighty clean, too.
-Schotte
LeRoy
09-07-2003 16:22:26
Thank you very much for that info. Was wondering if some one had used the 11544b housing and put the correct jets and venturi in it, but it looks like I will be looking for another carb.
Thanks again Mike for that info.
LeRoy
