Case 311 pto clutch
Patrick Foley
09-06-2003 18:05:01
I have a 311 with a hand pto clutch that needs adjustment. My manual shows how to for the 400 not 311. Had clutch work done about seven years ago, never used the pto that much untill this year got a brush-hog. The pto clutch engages very easy, it's also makes the tractor slip in road gear unless you hold up on the handle. It doesn't do it all the time, I adjusted the foot clutch as the manual states, still the same. Thanks Pat
george md
09-07-2003 10:57:47
 Re: Case 311 pto clutch in reply to Patrick Foley, 09-06-2003 18:05:01
Pat, On the case tractors with foot and hand clutch,
both will disengage the transmissions. The foot clutch also disengages the pto ( system is called
constant running pto ) . To adjust the hand clutch,
remove the cover from the range trans , and (with
the hand clutch disengaged)locate the two pins in the cltch hub one will be in and one will be pulled out. Pull the one that is in out and rotate the
hub clockwise untill other pin drops in , pull
other pin and repeat untill first pin drops in, continue untill handle requires about 50 pounds
of force to snap over center. Replace trans
cover .
george
Patrick Foley
09-07-2003 11:06:35
 Re: Re: Case 311 pto clutch in reply to george md, 09-07-2003 10:57:47
Thank You George! I'll give that a try as soon as I can get to it. Pat
Ken McWilliams
09-07-2003 03:31:34
Pat,
The dry-disc manual clutches provide all the power from the engine through to the "road gear" AND the PTO. The PTO shaft comes from the back end of the transmission's main shaft and is non- live PTO. Only the CASE-O-Matics had live PTO.
The bush hog is taking the extra power through the main clutch and probably why you didn't notice it before. You will probably need a new clutch disk and maybe re-surface the flywheel. Nearly all the CASE tractors that I've rebuilt had a deep depression where the clutch disk wore into the flywheel's surface.
Breaking a tractor in the middle for clutch replacement is not that difficult. You need a good concrete floor and 2 rolling floor jacks or a chain hoist and one rolling floor jack. Been there, done that.
When Terrance sends the PTO adjusting information, it will seem complicated at first, but it is easier than first thought. Read the instructions carefully. You have a small hole to work through, but tightening the PTO clutch is not that difficult. I did my first one the hard way and took it apart to determine how it worked and to adjust it. You don't want to do that unless you have 4 hands.
Ken McWilliams
Dayton, OH
Terrance
09-06-2003 18:58:55
Pat, I can send you a scan of the manual pages that apply. Hope this helps
Terrance
Patrick Foley
09-07-2003 03:56:56
 Re: Re: Case 311 pto clutch in reply to Terrance, 09-06-2003 18:58:55
Thank You Terrance that would be very helpful. [email protected]
Terrance
09-07-2003 12:11:57
 Re: Re: Re: Case 311 pto clutch in reply to Patrick Foley, 09-07-2003 03:56:56
Pat, your mailbox is full. When you are expecting scans you should be sure that you have enough room in your mail. It is a pain to upload them then a short while later have to wait while they download back onto my computer because you have a full mailbox. Send me an email when you have some room and I'll resend.
Thank You Terrance
