995 david brown
KJ
09-06-2003 06:42:21
need info on tractor ie used serv manuals has a case f/e loader and the factory hydrolics do not seem to operate properly
Elmer
09-07-2003 06:38:19
 Re: 995 david brown in reply to KJ, 09-06-2003 06:42:21
I can help you out with literature.
kyhayman
09-06-2003 19:06:19
Need a little more info. Does it have a 2 stage clutch pedal or PTO clutch lever? If ot has the lever and tranmssion mounted pump then the lever has to be forward/down (depending on style) for the pump to work. If it isnt this it may be a little more serious. Next thing is look at the fluid. These tractors are prone to getting water in the transmission and a little water goes a long way toward doing bad things to the hydraulics.
