case 300
Mike
09-05-2003 08:44:42
Can tractor fluid be used in the transmision and hydraulics for this tractor. I do not have a book on this model and a friend of mine lent it to me to use as long as I need it, have had it 18 months already. I filled up the power steering unit with it already and seems ok. Where are all the fill plugs on this model? Thanks in advance
C. Amick,
09-05-2003 09:26:34
 Re: case 300 in reply to Mike, 09-05-2003 08:44:42
I use 30w. motor oil in my hydraulic reservoir. I think this is what my book called for. You will loose some of the fluid (motor oil)into the the rear transmission due to leaking seals on the rear lift. The rear transmission has gear oil in it. I figured it would be better for the motor oil and gear oil to mix than for the hydraulic fluid to mix with the gear oil, but I guess it probably doesn't matter.
John Saeli
09-05-2003 09:02:33
Hey Mike: The 300 has 2 separate housings. The Range & Hyd. housing is 1. It is under the steering shaft, ahead of the 4 speed shifter. It will have a fill plug & dipstick. Transmission-hyd. fluid is fine, although I add a little 85-140 gear oil to mine. The trans.- rear end housing is the 2nd housing. Just in back of the 4 speed shifter is a rather large plug with a dipstick on it. Fill that housing with 85W-140.
