LA case
Vern Iowa
09-05-2003 07:31:28
I would like to replace the brake cylinder in the rear wheels of the LA. How do you remove the rear hub? There are 2 bolt holes on either side of the large retaining burr on the axle. Do I put a heavy piece of metal across the end of the axle and two bolts in each hole to pull the hub, or do I screw two bolts in to the holes and they will push the hub off? I would loosen the large burr in each situation to keep the hub from slidding off the axle when it came loose. Which way is the right way. I sure appreciate any suggestion.
Tom Railsback
09-07-2003 19:50:13
 Re: LA case in reply to Vern Iowa, 09-05-2003 07:31:28
You will proably need to heat everything once you have your puller set. A large propane weed burner works about the best.
The brake cylinders were made by Wagner-Lockheed.
Their Master Cylinder Kit Number was FC53754 and the wheel cylinder kit was FC3618; Case numbers were B59400 and B59399 respectively. Of course, this data is 25 years old as that's the last time I workes on an LA with hydraulic brakes.
Jim P
09-06-2003 21:37:11
My Dad bought a new 1948 LA and it had Hyda brakes . The master cyld's always would pump up from field vibrations. After much working on them we just drained out the fuild and run it without brakes for 20 yrs. It just had the emergency brake. Some corners slid a lot but with the swinging drawbar we got buy. Never did pull a wheel.
RobertTX
09-06-2003 18:55:08
These can be VERY hard to remove. Worst part is, I do not believe the brake parts are available any more. The hubs are difficult enough to get off that you ought to look into brake parts first. The wheel cylinders are huge, I do not remember the size. Maybe you could visit a salvage yard to look at one that has been taken apart. Good luck, if you want to email me, I am at [email protected].
Gene dotson
09-05-2003 08:55:52
Vern; When I pulled mine, I used a 1" by 3" piece of bar stock and drilled matching holes for the puller holes in the hub. I then used double ended studs and seated them firmly in the bottom of the holes after cleaning the threads with a 3/4x10 tap. Use nuts on the outer end of the studs with hard washers under them. It will take a substantial amount of force to break them loose. You will need a substantial lifting device because they weigh about 800 pounds each. They are on a tapered shaft and once broken loose they are free to come off. Leave the axle retaining nut flush with the end of the axle until it is loose to keep things from falling... Gene
