990 case
dan
09-04-2003 17:50:40
red and orange light stay lit when tractor is running can't seem to find any thing wrong could it be in the ignition.
Dale(MS)
09-06-2003 05:58:36
 Re: 990 case in reply to dan, 09-04-2003 17:50:40
Dan, lights should go out if hydralic filter and fluid are in good shape. Give tractor time to warm up and with rpms above say 1200 the lights should go out. Check hydralic fluid at dip stick by left knee as sitting on the tractor, keep mine about 1/4 inch above full mark on stick, seems like the lights work better with it a bit high. Paper filter element probally needs to be changed anually.If transmission shifter boots are bad and there is water in the tranny you need to change filter, fluid, and boots. Can't recall amount of fluid needed off the top of my head. HTHs Dale
Elmer
09-06-2003 05:55:31
There is a diode in the harnes between those two lights. Make sure it is allowing current only one way.
Dale(MS)
09-06-2003 06:09:42
 Re: Re: 990 case in reply to Elmer, 09-06-2003 05:55:31
Elmer, forgot about the diode in that harness! There is one in the alternator also that my armature shop missed twice before it was finally fixed right. Dale
