SC front wheel bearings
gerald
09-03-2003 16:19:41
Anyone had any experience with getting the inner bearings out of an SC with dual front wheels. Do you need a puller or special pry bars to get it out?. I'm replacing the bearings, so not too concerned about saving the bearing. Any handy, dandy hints would be appreciated.
D Smoker
09-05-2003 16:52:47
 Re: SC front wheel bearings in reply to gerald , 09-03-2003 16:19:41
If it's the race you want to get out run a bead of weld on the face of the race. When it cools and the weld shrinks it will come out.
gerald
09-08-2003 19:18:55
 Re: Re: SC front wheel bearings in reply to D Smoker, 09-05-2003 16:52:47
It is the inner bearing that is stuck on the axle. The race is in the wheel. Those (inner and outer) I should be able to punch out from opposite sides. Its the bearing that there seems no way to get out without getting a pry behind it. In order to make room for small pry bars, the roller part of the bearing will need to be destroyed. The outer bearing just fell apart when I took off the wheel. The inner one remains intact.
Fredct
09-03-2003 19:38:21
Gerald, I had good luck getting an inner bearing race out of a tough spot by just heating it with the old "heat wrench" and when it cooled it just dropped right out. I hope this is what you were looking for! Good luck! Fredct
gerald
09-04-2003 11:16:39
 Re: Re: SC front wheel bearings in reply to Fredct, 09-03-2003 19:38:21
Thanks for the tip. Tried heating for about 4 minutes with Mapp gas. Let it cool, but no luck, Tried prying on the bearing with small right angle pry tools--no luck. I'll wait til I get the new bearings before I mess with it anymore. I'll probably have to destroy the bearing part in order to get a pry behind the race. With the bearing in there--no room to get behind to pry. Every day has a new challenge. Such is life.
