TSX 635 stuck float seat
KeithA NNY
09-03-2003 07:28:32
Rebuilding carb. on my 311b and the
Float seat is stuck fast to carb housing.
Any suggestions to get it out?
Glen in TX
09-03-2003 08:55:40
 Re: TSX 635 stuck float seat in reply to KeithA NNY, 09-03-2003 07:28:32
Grind a screwdriver to fit the slot exactly in the seat. Soak with some penetrating oil and tap lightly. Or rinse all fuel out or penetrating oil out and heat carefully with a heat gun or hair dryer, not a torch. Or grab with a pair of pliers and lower carb into a pan of hot water and then try with patience. Good luck.
