Case D oil pump
Garri
09-02-2003 23:32:53
I am still working on a Case D and desperately need some help / advice regarding the oil pump. I have done an inframe overhaul and have no oil pressure. I have tried different gauges. I have also taken oil lines loose and no oil comes out while cranking or pulling the tractor. I have taken the relief plunger nut and spring out. I have not been able to get the plunger out. There was lots of thick sludge and goop in the oil pump. I have also taken the pipe plug out from the side of the oil pump and filled the oil pan with Marvel Mystery oil, diesel and Kroil. It has sat for 2 months soaking in this mixture. With the mixture still in the oil pan, we pulled the tractor in hopes of building pressure and "blowing" the plunger out. Still nothing. My question is, Does anyone have any ideas on how to get the plunger out or to get the pump "pumping". I do have an I&T manual, parts manual and operators manual but, there is nothing in the books about this problem. Or, does anyone want to buy a complete Case D with new rear tires and rims. I'm 'bout out of patience. Thanks in advance. 405-202-1741.
dctom
09-03-2003 07:12:04
 Re: Case D oil pump in reply to Garri, 09-02-2003 23:32:53
Gerri : if you would want a pump i have some here that came from runnning tractors, e mail me if you are intrested, [email protected] tom
Klyde
09-03-2003 04:44:38
they were a cup valve, tap it back in and use a piece of tapered dowel rod to twist and pull and push till it can be pulled out.
