Model V or VA clutch specification needed ???
Alberta Mike
09-02-2003 14:32:45
I am reassembling a 3-spring Auburn clutch on a Case model V. It would be pretty much the same clutch as is on the VA. I replaced the throwout arms and springs on the pressure plate assembly. Now I need to adjust the height of each of the three arms using the adjusting bolts and lock nuts. I know that all three arms have to be adjusted to the same location or height (within 0.005" of each other) but I don't know at what location or height to adjust the arms to. None of the manuals I have here give a specification nor do they state where to take the measurement from. Any help or advice would be appreciated if you might be able to help.
