Stuck in 4th gear
Gary Cash
09-02-2003 14:19:05
My 1945 Case VAC is stuck in 4th gear. This happened after driving the tractor around my property and down a paved road for about 1/4 mile in 4th gear. The gear lever position is in neutral. I can start and operate the tractor in 4th gear by depressing the clutch but as soon as I try to shift it to another gear, it will only go into what appears to be the reverse gate. In the reverse gate the tranny locks up and the engine dies as the clutch is released.
dctom
09-02-2003 14:34:58
 Re: Stuck in 4th gear in reply to Gary Cash, 09-02-2003 14:19:05
Gary: you are stuck in 4th gear finger has slipped out, remedy take top off transmission and work shift rails to nutural than put top back on making sure shift finger is in nutural posision, than you will be able to shift, cause, shift finger is worn or bent so it slipps out of socket good luck tom
Gary Cash
09-03-2003 15:33:26
 Re: Re: Stuck in 4th gear in reply to dctom, 09-02-2003 14:34:58
As you and Jerry recommended, I took the shifter assembly off of the tranny. It was somewhat difficult to remove, required considerable wiggling, as the shift fingers/gears were out of proper alignment.
The fingers looked fine with just some wear on the most forward of the three fingers. Once the gears were all disengaged, I smeared the fingers and gear journals with white grease and reassembled. The tranny now shifts just fine.
Thanks again guys.
Jerry
09-03-2003 16:39:23
 Re: Re: Re: Stuck in 4th gear in reply to Gary Cash, 09-03-2003 15:33:26
Gary, Job well done.Now don't you feel good ?
A case friend, Jerry
Gary Cash
09-02-2003 23:02:56
dctom,
Will do, Thank you.
