Correct SC Cultivator Shaft Size? Mike Schotte
C. Amick
09-02-2003 09:08:01
Mike, what is the correct front cultivator shaft size ( outside diameter)?
Mike Schotte
09-02-2003 16:48:13
 Re: Correct SC Cultivator Shaft Size? Mike Schotte in reply to C. Amick, 09-02-2003 09:08:01
Hey Myron,
I don't want to lie to you... I really don't know (and the tractor ain't handy.)
I *think* that the cultivator bracket holes in the fully closed position are around 2-1/2". The cultivator shaft would probably have to be bigger than that so you could clamp down on it tightly.
I've got a parts catalog for a DC mounted cultivator... but it does not give any sizes for the part.
Sorry.
-Schotte
okla/kans Bill
09-03-2003 12:01:42
 Re: Re: Correct SC Cultivator Shaft Size? Mike Sch in reply to Mike Schotte, 09-02-2003 16:48:13
I have a DC Cultivator I use on my CC If you want ill get a measurment on the shafts. Its a darn good cultivator
C. Amick
09-03-2003 14:21:05
 Re: Re: Re: Correct SC Cultivator Shaft Size? Mike in reply to okla/kans Bill, 09-03-2003 12:01:42
That would be helpful. I could measure the opening, but I still might not get it right. Is it a square shaft?
okla/Kans Bill
09-03-2003 14:35:43
 Re: Re: Re: Re: Correct SC Cultivator Shaft Size? in reply to C. Amick, 09-03-2003 14:21:05
Yes its square, all the CC Dc abd SC shafts were square. Its 2 1/2 sz but a SC may b different
bob
09-04-2003 12:32:11
 Re: Re: Re: Re: Re: Correct SC Cultivator Shaft Si in reply to okla/Kans Bill, 09-03-2003 14:35:43
I just welded up some front end loader brackects for my 43 SC- 2.5 inch square tubing fits nice and tight even when the nuts are not fully tighetned.
Okla.Kans Bill
09-04-2003 17:12:36
 Re: Re: Re: Re: Re: Re: Correct SC Cultivator Shaf in reply to bob, 09-04-2003 12:32:11
The clamps will not clse completly against the square tubing on the cultivator. Are you going to use it to plow corn, or just to hang on the tractor for show. Iuse mine and love it. Easiest cultivator I ever put on, and ive put on JD and IHC 40s era
