Tractor pulling a VAC
Tim Harrell
09-01-2003 15:40:34
I am thinking about pulling my VAC in a tractor pull. I would like to have as much power as I can get. I was thinking about putting a engine from a 530 case into my VAC. Does anyone know if that engine would blot up and if not which ones would?
raymond
09-10-2003 18:44:20
 Re: Tractor pulling a VAC in reply to Tim Harrell, 09-01-2003 15:40:34
The old 148s will bolt in. The newer 148s will not. What you need to look at is the casting around the starter. The 148 that will bolt in has no casting around the starter. Now, the crank and misc. parts out of a 159 engine are supposed to bolt into the 148 block with a little machining. I know of a guy in Ohio (where I am) that has done about all there is to do to one of those motors. I have no idea what the guy is talking about that says he has a 188 motor in his VAC. Not possible as far as I know. Also, 148 blocks that aren't cracked (they were known for that) are hard to come by. Keep us informed on what you find out and are going to do.
Jim
09-04-2003 19:22:17
I am working on a similar project and read that the 148 block will not bolt in a VAC but the 148 guts will fit in the VAC block (quite common pulling upgrade). I also heard that the 148 is not enough to compete with the Allis WC/WDs of this class, WC running a WD block has 226 displ. The 148 engine was used in the Case 400B and 430. Anyone know what the 164 or 188 was used in and what it takes to get these in a VAC. What is the next step above the 188 ?
09-02-2003 17:52:29
You can bolt in a 148, 164, without any real mods.
I have a 148, with the head cut as far as possible.Compression is the key plus rpm's
good luck
Tim
09-02-2003 10:20:00
I have a VAC with a 188 engine 45-50 horse. I have been thinking of selling the tractor. I just dont have the time to pull it anymore. I can give ou the info if you wish.330-435-4568
C. Amick
09-02-2003 09:17:09
I've heard that you can put the internal components from a 300 series tractor into a VAC block. I think you would be going from 123 cubic inches to 148 cubic inches.
