Model 701-B Overheating
Steve McGeorge
09-01-2003 15:28:50
My Dad bought a Case model 701-B (diesel) two months ago, and after discovering major engine problems, had replaced both heads, and all powercells, (it was missing one powercell when he bought it) sent the crank out and had the No. 3 rod journal built back up, and the crank reground. Replaced the No. 3 sleeve (used), Honed the cylinders and installed new piston rings, Had the injectors checked out, and they were above specs. This weekend, we fired it up for the first time, with no problems, chased fuel leaks etc. nice clean exhaust. Well, after I left his house, he hooked up to a disc, to finish what he had started two months ago, and an hour later calls me up saying that the lower half of the engine is overheating,,, turning the pain black at aroung 240-280 degrees. However, the cylinder temperature is around 180, with the water temp gauge reading 190. My first guess is that the rings had not seated in fully , and blow by is causeing the high temp, but he didn't notice any blowby coming from the crankcase.
Any Ideas?
