VAC Project: Need a part
F-I-T
09-01-2003 12:21:09
Tractor had very stiff steering....found out why today. The stub of the steering shaft where the worm gear mounts is bent to the tune of .155". So much so that it cannot be removed from the cast housing. I'm afraid if I heat that end cheery red and give it a wack I might break the casting.
So, I'd like to find a usable shaft. I'm pretty sure it's numbered VTA-2841 as it is 39 5/16" long. Tractor S/N is 5459267. I have the Case parts book R.I. D61, adn that;'s where I got the information.
I figure that if I have a straight shaft I'll cut off the bent end and drive the old one out. Better yet, maybe I can buy the shaft and the casting together.
Anyone out there have such an animal ?
Thanks !
Frank-in-Tallahassee
70D // 855 // VAC
F-I-T
09-02-2003 05:07:10
 Re: Re: VAC Project: Need a part in reply to Jeff, 09-01-2003 20:16:18
Thanks Jeff !
Dave True
09-01-2003 18:46:26
 Re: VAC Project: Need a part in reply to F-I-T, 09-01-2003 12:21:09
F-i-t there are some vac steering parts in the auction section this site under parts on the 2nd page have a good week Dave.
F-I-T
09-01-2003 18:55:57
 Re: Re: VAC Project: Need a part in reply to Dave True, 09-01-2003 18:46:26
Thanks Dave, but I have those pieces. I did get an e-mail from a fella. Looks like he'll be able to fix me up !
Frank
