Late model DC-4 Wide front
Ted
09-01-2003 02:55:49
Does anyone know of a late model DC-4 widefront available. I'm talking about the model with a fixed axel, but that mounted at the front of the tractor not under the radiator like the earlier models. I am not looking for an adjustable front end
John H-WI
09-01-2003 06:41:18
 Re: Late model DC-4 Wide front in reply to Ted, 09-01-2003 02:55:49
Ted, not quite sure from your post which front you are speaking of. All DC-4's had the axle under the radiator. If the axle is in front of the tractor it would be a DC-3 with a wide adjustable front. Search the tractor photos for Case. There should be a picture of both. Never seen a DC-4 without the axle under the radiator. Neighbor had three of them over the years while I was on the farm.
Ted
09-01-2003 07:43:15
 Re: Re: Late model DC-4 Wide front in reply to John H-WI, 09-01-2003 06:41:18
John, I know what you mean, I never saw one until last year, but there is another model that was produced later. It is a fixed axle and mounts at the front of the cast in front of the radiator giving the DC-4 about a 12" longer wheel base. If I can find a picture I will post a copy.
dctom
09-01-2003 08:01:43
 Re: Re: Re: Late model DC-4 Wide front in reply to Ted, 09-01-2003 07:43:15
Yes 1954 what we all call the heart shaped front end big casting that adds 12 inches to the wheel base of a DC4 solid non adjustable axle
DCtom
John-WI
09-01-2003 13:39:37
 Re: Re: Re: Re: Late model DC-4 Wide front in reply to dctom, 09-01-2003 08:01:43
DCTom or anyone else for that matter. Could someone post a picture of the DC-4 with the extended front? I don't recall of seeing one. Would appreciate having a looksee. Do know the regular 4's were a tad light on the front in the hills.
