Case 530 CK Hydraulic Pump
Phil (NJ-AZ-SK)
08-31-2003 14:55:10
I need an Exchange unit.. Cessna (markings on Mounting Flange) 3G-22-0C... L24S04-LAN
The Seal failed on mine, but it was not working very well (slow) and the Shaft has only a little bit of Spline (worn Out) that engages the Coupler.
What are sources for an exchange/Re-built
Thanks,
DaleIN
09-01-2003 14:03:30
 Re: Case 530 CK Hydraulic Pump in reply to Phil (NJ-AZ-SK), 08-31-2003 14:55:10
Hello,
I stock new aftermarket pumps for 530CK. It usually isn't worthwhile to rebuild this type of pump. I also keep the 4 bolt, shaft, & sleeve drive couplings, plus a bunch of other parts for Case hoes. Thanks, Dale
Charley
08-31-2003 17:56:09
Case dealers still have them. Not too pricey either.
