Case 2090 clutch noise
Tom
08-31-2003 05:58:13
I recently purchased a Case 2090. After replacing the in cab clutch pedal return spring and filling the tractor with hydraulic fluid the clutch has developed a noise. When the pedal is pushed in and let out the clutch works w/o any noise but, when the pedal has about a quarter inch left until it is returned to top center. At this point it develops a whine/noise. once I pull the pedal past this point it stops. Can any one give me some help?
john m
08-31-2003 19:04:07
 Re: Case 2090 clutch noise in reply to Tom, 08-31-2003 05:58:13
The clutch pedal must return fully with return spring pressure only. Sounds like it's still sticking. You can add 2 return springs by adding a long bolt in pedal to hook springs on both sides. The cable should be replaced also. The hyd noise you hear at near top pedal is oil leaking by for clutch modulation. Normal.
