Stuck DC
Ted Olbrich
08-31-2003 03:23:48
I have a 53 DC that ran a few years ago. The engine is stuck, and I've tried "marvel oil", filling the cylinders with diesel, sticking it in 4th gear and rocking it backwards with a crowbar. So far, no luck. I suppose I can pull the head but I'd rather not. Anyone with anymore ideas??? One guy told me olive oil works. Did you ever hear of that? Or, is he pulling my leg? If I put it in 4th and try pulling it backwards what are the chances of snaping a chain or bending a rod?
Dave
09-01-2003 07:27:32
 Re: Stuck DC in reply to Ted Olbrich, 08-31-2003 03:23:48
I have always had good luck with transmision fluid,let it set a week and try is all you can do. But before doing any more take the valve cover off and make sure all the valves are free so not to bend a pushrod or two or three(been there and got the T-Shirt). We have broken them by putting the clutch in gear(trans in neutal) and kicking the belt pulley. If that don't get it pull it and work the clutch gently, never hurt one yet and we have unstuck a bunch. Good luck, Dave
Dave True
08-31-2003 18:10:12
hi Ted i had a engine that was stuck and could not get it to budge. so i put the hand crank on it and hung a wheel weight on it putting pressure on the crank putting pressure on the piston and it took a week or so but it did break it loose i also used a prduct called kriol a friend gave it to me and iam not sure where to get it you might post a message on here to see if anyone knows where to get it. thanks and have a good week Dave
Bob D. (La)
08-31-2003 18:23:58
 Re: Re: Stuck DC in reply to Dave True, 08-31-2003 18:10:12
Dave, I just got the last frozen piston out of my Allis C. I purchased it frozen in May. Initially soaked in diesel/marvel mystery oil.After a month with no success, I switched to PB Blaster. By July I had three of four pistons removed. Finally, ordered from Kano Labs some Kroil. It took an additional month but last piston finally freed up. I did pull the head though and oil pan. Good thing too, as there was so much build up of rust/gunk, under the rings,it would probably have destroyed the sleeves had I gotten it unstuck without pulling pistons out. Am in process of honing sleeves, looks like all are ok. Will have to rering and already have redone head. PS: Also had stuck valves so guess what I'm trying to say is you really should pull it apart. If it's not free already, you could do a lot of damage trying anything less. Bob D.
