530 CK hydrostatic Steering, won't steer? Help!!!
Jeff
08-30-2003 15:58:16
Hi again, I changed the filter and I still get nothing? when I turn the wheel I can see one steering cylinder move about 3/4" in and the out? do the cylinders need to be re sealed? or is the pump shot? Thank You Jeff.
Phil (NJ-AZ-SK)
08-31-2003 15:20:25
 Re: 530 CK hydrostatic Steering, won't steer? Help in reply to Jeff, 08-30-2003 15:58:16
Jeff, My case 530 CK has a manual pump that is driven by the Steering wheel (part of the assy of the Steering wheel) The Power Pump provides pressure to the Control Valve and to the Manual Pump, the Stator/Rotor/Commutator of the manual Pump directs the Oil to the CorrectCylinder.
You should be able to steer the tractor without the Power Pump Working.. Just using the Manual Pump.. and Arm-strong
Hope this Helps,
