Stuck engine blues
Edwin
08-30-2003 09:34:59
I am working on a 37 CC that is free until the center pistons come up then she sticks fast. I can back it out all the way around to about the same point and the same thing happens. The engine was turning about a year and a half ago but I got busy and set it aside for awile and this is my reward. I've tried hammers and wood blocks, rocking in gear, etc. Any one else had this happen,? Would anything besides the piston cause it to stick (e.g. rust or gunk on timing gear teeth)
Thanks
dctom
08-30-2003 09:53:01
 Re: Stuck engine blues in reply to Edwin, 08-30-2003 09:34:59
ED. if you have the head off try honeing the top of the sleeves on thoes two maybe got rusty at the top. can you back it all the way aroung till thoes two come back up ? if so than it cant be the botton of one and four, back her around and hook on and give her a yank, she should go all the way over than good luck tom
Edwin
08-31-2003 05:48:11
 Re: Re: Stuck engine blues in reply to dctom, 08-30-2003 09:53:01
Thanks, I'll try it. If it was the bottom of 1 and 4 what would I do? Pull em out?
Robert Cannons
08-31-2003 03:25:43
you could have a stuck valve stopping the piston from turning all the way . my 600 had a stuck valve and it broke 1 piston really good.
Edwin
08-31-2003 05:42:00
 Re: Re: Re: Stuck engine blues in reply to Robert Cannons, 08-31-2003 03:25:43
The head is off, no valves involved.
