830 COM GRINDING GEARS
KIRK
08-29-2003 20:54:43
I JUST BOUGHT MY DAD'S 830 CASE THAT HE BOUGHT NEW IN 1964. IT HAD ONE OTHER OWNER FOR THE LAST 15-20 YEARS AND NOT USED MUCH. THE PROBLEM IS TRYING TO GET IT IN GEAR. BOTH SHIFTERS SEEM TO GRIND BADLY WITH THE COM PEDDLE PUSHED IN. ONCE MOVING EVERYTHING WORKS GOOD. THANK YOU AHEAD OF TIME FOR YOUR RESPONSE.
Roger
08-29-2003 21:39:00
 Re: 830 COM GRINDING GEARS in reply to KIRK, 08-29-2003 20:54:43
Most or all of them will do that when you first put them in gear, it's worse in winter especially if using oil heavier than ATF in the convertor. Idle down as slow as possible will help too. I try not to change gears until I stop completely after I've been moving. There isn't really anything to completely stop the convertor in there, that's why they grind when first putting them in gear
KIRK
09-01-2003 08:51:13
 Re: Re: 830 COM GRINDING GEARS in reply to Roger, 08-29-2003 21:39:00
THANKS ROGER. I WAS CONCERNED ABOUT HARMING THE GEARS. I'LL TRY IDLING DOWN.
