Head Gasket and Fire Ring Installation Case 1030
Steve
08-29-2003 20:52:26
I am trying to figure out how to install the fire rings properly on a Case 1030 head. Does any one know if they are absolutly needed and why?
Roger
08-29-2003 21:50:59
 Re: Head Gasket and Fire Ring Installation Case 10 in reply to Steve, 08-29-2003 20:52:26
Fire rings are installed with the lip down (If you understand what I mean, its kinda hard to explain) They are available in different thicknesses, you need to determine how much each sleeve protrudes above the surface of the block to know which ring to use if it's more than 2 thousandths use a standard thickness ring, if less than 2 thousandths use a thick ring that is marked with a blue stripe
Steve
08-30-2003 06:38:43
 Re: Re: Head Gasket and Fire Ring Installation Cas in reply to Roger, 08-29-2003 21:50:59
Thanks Roger. So the more the sleeve sticks up the thicker the ring. Is the ring used to keep the gasket from blowing?
Roger
08-30-2003 10:13:50
 Re: Re: Re: Head Gasket and Fire Ring Installation in reply to Steve, 08-30-2003 06:38:43
no use the thick ring if the sleeve sticks up LESS than .002 a standard one for more than .002 height
Jim Handke
08-30-2003 07:22:02
That's correct. And if I remember correctly, the bottom of the ring is flat and the top slightly rounded.
Steve
08-30-2003 08:05:01
 Re: Re: Re: Re: Head Gasket and Fire Ring Installa in reply to Jim Handke, 08-30-2003 07:22:02
What if the protrusions are not the same? Should I put a thicker one on one cylinder and a thinner one on the other?
Roger
08-30-2003 10:11:56
 Re: Re: Re: Re: Re: Head Gasket and Fire Ring Inst in reply to Steve, 08-30-2003 08:05:01
Yes put a thick one in one hole & a thin one in the other if necessary
PHil Munson
08-30-2003 09:29:42
The fire ring IS the gasket that keeps the exhaust gases in. The lower the sleeve the thicker the fire ring, to make all cylinders have equal sealing pressure. DO IT VERY CAREFULLY AND YOU WILL BE REWARDED WITH A GOOD RUNNING MACHINE. I don't have the book in front of me but it seems to me that you have to be within .002 on each head.
