still looking for help on 1370
ralph
08-29-2003 14:25:09
I split the tractor and the planatary seems fine. Any other suggestions?
RoyG
08-29-2003 19:18:40
 Re: still looking for help on 1370 in reply to ralph, 08-29-2003 14:25:09
I am sure you have already checked but, Make sure you check the splines and balance of the C-1 clutch plates as they have to turn backwards in reverse and when the inching pedal is depressed.
I have seen them split and loose the splines in the plates and that willcause a vibration. Just hope this may help. RoyG
John Saeli
08-29-2003 17:47:41
Hey Ralph!! How did the oil look? Did it contain brass shavings?
Ralph
08-29-2003 18:35:35
 Re: Re: still looking for help on 1370 in reply to John Saeli, 08-29-2003 17:47:41
No brass shavings, some steel shavings and a small snap ring. Can't seem to find anything wrong.
John Saeli
08-30-2003 17:47:54
 Re: Re: Re: still looking for help on 1370 in reply to Ralph, 08-29-2003 18:35:35
Hey Ralph; Have you found the problem yet?
Ralph
08-30-2003 19:16:56
 Re: Re: Re: Re: still looking for help on 1370 in reply to John Saeli, 08-30-2003 17:47:54
Found the problem, the bolts came out of the flange retainer holding the planetary gears. Broke a couple of gears. Anybody know if this is a common problem or knows what happened.
Bob Clark
08-31-2003 19:45:27
 Re: Re: Re: Re: Re: still looking for help on 1370 in reply to Ralph, 08-30-2003 19:16:56
If these are the 3/8ths or 7/16ths 12 point bolts that hold C2-3 clutch packs and planet gears together it is very common. Get a service manual and track down parts with large bolts.
