Best way to add weight to front of SC?
C. Amick
08-29-2003 12:59:57
This tractor has so much horsepower that I can't keep the front end on the ground. Not really, what's causing the problem is the disc mower that's on the rear. I have 2 cast iron front wheels and the weight that sits in front of the radiator. I'm thinking of adding more weight by mounting something in the cultivator holes.
lizzy
11-13-2003 07:06:24
 Re: Best way to add weight to front of SC? in reply to C. Amick, 08-29-2003 12:59:57
Please I want to increase my weight. I need someone to tell me what I will take to increase my weight I want to get fat.
Thank you.
case poor in pa
09-02-2003 17:03:56
i can put a 105 lb blonde in a thong on my 730 hood.. holds it down and look good
C. Amick
09-03-2003 05:24:51
 Re: Re: Best way to add weight to front of SC? in reply to case poor in pa, 09-02-2003 17:03:56
I can try that, but won't it make it difficult to keep my mind on farming?
todd hamilton
08-31-2003 10:35:29
Dad's SC had an LP head to boost horsepower. When plowing in red dirt stop and shift into first. As soon as you throw the clutch grab the steering wheel with both hands and stand on the right or left brake as needed to steer (stay straight or get yelled at). Dad always said it would die before it went over but this 10 year old (at the time) didn't put much stock in that theory!
Mike Schotte
08-29-2003 16:19:32
Hey Myron,
I had a welder make me some hangers to slip into the cultivator bracket holes.
BRACKETS:
third party image
The angle is sized for an 100lb. IH suitcase weight:
third party image
I can reverse sides on the hangers to make them hang in either direction. (I also had him add a loop to attach a chain to if I ever want to drag something in reverse.)
-Schotte
Terry Nelson
08-30-2003 10:07:05
 Re: Re: Best way to add weight to front of SC? in reply to Mike Schotte, 08-29-2003 16:19:32
Good engineering Mike. Would they also make good sleeves to run chain through for trailer tie- down and still protect the paint?
Mike Schotte
08-30-2003 19:33:07
 Re: Re: Re: Best way to add weight to front of SC? in reply to Terry Nelson, 08-30-2003 10:07:05
Hi Bruce,
Yes- I suppose I could use them for hauling, too. SCs don't have that hoop underneath like the DCs do.
I don't have a trailer, so it never occurred to me.
Don't compliment my engineering too much... I messed up. I measured the cultivator bracket hole wrong (I didn't have the bottom halves I ordered from Don L. when I cooked this idea up.)
I don't know how I did it, but I used a 2"X2" square tube, and it's about a 1/2" too small. They'll fall right out!
I've found some 1/2 angle iron to put in there to take up the extra space- I just need to find somebody that can cut it to length for me.
When are you coming down this way again?
-Schotte
evo
11-12-2003 09:04:02
 Re: Re: Re: Re: Best way to add weight to front of in reply to Mike Schotte, 08-30-2003 19:33:07
im a tall lad 16 years old can you please help me put more weight on. I want to build my self up
John H-WI
08-29-2003 14:52:56
Thats about the only way you can add weights to the SC. You could also add fluid to the tires also. Depends on what you use the tractor for without the mower on. It would be easier to remove weights than take out fluid.
