507785 SC?
Josh
08-29-2003 07:16:35
I recently bought an old case sc. Does anyone know what year s.n. 507785 is? it has the flat wheels and deep fenders but the exhaust doesn't go through the hood. I also thought the serial number was supposed to be 7 digits? thanks!
chris
08-29-2003 20:25:35
 Re: 507785 SC? in reply to Josh, 08-29-2003 07:16:35
dctom, could you PLEASE look up the seriaL# 5423211DC. i would very much appreciate your time. i rescued this dc from a salvage yard and restored it ( very expensive but worth every cent ) curious to see the distance from where it was made to where it ended up? i plan on calling rich next week for a build sheet. thanks
dctom
08-30-2003 15:27:05
 Re: Re: 507785 SC? in reply to chris, 08-29-2003 20:25:35
JOSH: your tractor was built aug 23 1950 and shipped to ji case co omaha neb aug 29 1950
sorry little late but had a lot to do
hope this helps tom
dctom42
08-29-2003 09:30:03
Josh: just looked up build card, add the 4 and you get 4507785 SC built may 6 (my b day) 1941 and shipped to harrisburg pa
hope this helps tom
Josh
08-29-2003 11:14:22
 Re: Re: 507785 SC? in reply to dctom42, 08-29-2003 09:30:03
that sounds about right, harrisburg is where i found it. thanks!
dctom
08-29-2003 09:13:11
sounds like it must a 1941, look under the screw on sr. plate for a 4 or look on engine flange by air cleaner number should be stamped there also, dose it have chrome strips and libhts on the fenders? tom
RandyD
08-29-2003 11:21:42
 Re: Re: 507785 SC? in reply to dctom, 08-29-2003 09:13:11
Tom is it still possiable to get the build card information for my 1949 Case SC?
Randy
dctom
08-29-2003 14:26:00
 Re: Re: Re: 507785 SC? in reply to RandyD, 08-29-2003 11:21:42
Randy: yes i have it here just give me the serial number will look it up
JW
08-29-2003 16:35:24
 Re: Re: Re: Re: 507785 SC? in reply to dctom, 08-29-2003 14:26:00
Can you tell me anything about my 53 SC? SN# is 8028119. Thanks Joe
dctom42
08-29-2003 16:56:49
 Re: Re: Re: Re: Re: 507785 SC? in reply to JW, 08-29-2003 16:35:24
Yes your tractor 8028119 was built march 16 1953 and shipped march 17 to j i case branch house bettendorf iowa
fellow case collectors, i enjoy helping you out and i have al the original build cards here if you would like to have a copy of it you can call mr rich tworek at case 414 636 7274, and he will send you a copy for $7,00 i beleive thanks tom
RandyD
08-29-2003 15:05:26
Here it is Tom 5315691 SC
Thanks
RandyD
dctom
08-29-2003 16:52:16
 Re: Re: Re: Re: Re: 507785 SC? in reply to RandyD, 08-29-2003 15:05:26
Randy; your tractor 5315691 was build march 24 1949 and shipped march 25 1949 to j i case branch house atlanta ga.
RandyD
08-29-2003 17:06:47
 Re: Re: Re: Re: Re: Re: 507785 SC? in reply to dctom, 08-29-2003 16:52:16
Tom, might the build sheet show if it were shipped with a muffler or straight pipe?
Thanks so much for the information. This is my Grandfathers tractor and every bit of information that I can collect, I cherish.
Randy
dctom42
08-29-2003 17:27:47
 Re: Re: Re: Re: Re: Re: Re: 507785 SC? in reply to RandyD, 08-29-2003 17:06:47
Randy; no it wont as mufflers were a dealer option, it only tells carb, mag, and tire size and maybe font axle arrangement ie wide adj or single and long axle in rear if it had one also starter and lights and eagle hitch if new enough tom
Randy
08-29-2003 17:44:14
 Re: Re: Re: Re: Re: Re: Re: Re: 507785 SC? in reply to dctom42, 08-29-2003 17:27:47
Thanks Tom.
The dealer option information on the muffler is good to know.
Have a good evening, you have made mine a good one.
Randy
dctom
08-29-2003 17:48:54
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 507785 SC? in reply to Randy, 08-29-2003 17:44:14
ALWAYS GLAD TO HELP TRY TO DO THE BEST I CAN WITH WHAT I HAVE TO DO WITH GOOD LUCK TOM
JW
08-29-2003 19:14:17
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 507785 SC? in reply to dctom, 08-29-2003 17:48:54
Thank you very much, the tractor was sold new at Hinckley, IL by Nehring Imp on July 2 1954 if you were interested. (written on inside of owners manual) Thanks again, Joe
