case 1394 clutch wont disengage
Wayne Ragsdale
08-27-2003 14:29:25
Looking for some help with this one. I have a case 1394 that came to the shop with what appeared to be a bad clutch. We put a new clutch in and still have the same problem, it does not seem to dis engage. Since we initially tore it down we havent had it running, but sitting still with the clutch pedal pushed in the tractor will not roll. We have had the tractor broken apart and in gear and are able to watch the input shaft turn, everything in the transmission seems normal.We have taken the clutch out sent it to a dealer to have it set up and still have the same problem. Am I overlooking something simple?? All the symptoms lead to clutch, but I am having difficulty beleiving this is the problem. Any advice or opinions on this would be more than appreciated.
Elmer
08-28-2003 15:14:58
 Re: case 1394 clutch wont disengage in reply to Wayne Ragsdale, 08-27-2003 14:29:25
Did you have the disc replaced. I think that tractor has the Laycock clutch in it. I don't think it is possible to install it backwards. They have a huge offset hub on them. Make sure your cross shaft has no wear. Maybe your not getting enough release. Is it a cab tractor, if so the slave cylinder link may need adjusting. Memory is starting to fail me. If it is a cab tractor i can look at the neighbours to bring back the past!
wayne ragsdale
08-29-2003 08:22:54
 Re: Re: case 1394 clutch wont disengage in reply to Elmer, 08-28-2003 15:14:58
No it doesnt have a cab, and yes it has the big hub so it will only go one way. I am starting to get the feeling that this may be one for the dealer! Thanks for the input Elmer.
norm
08-28-2003 04:38:49
have you checked the splines that the clutch slides on .may have notches or wear ridge stopping friction plate moving
wayne ragsdale
08-28-2003 05:58:08
 Re: Re: case 1394 clutch wont disengage in reply to norm, 08-28-2003 04:38:49
Just off of a glance the splines appeared okay, maybe this is something I need to look into a little further though. Will that cause a sudden failure or would it be gradual?? When it orignally failed it just happened suddenly. Thanks for your help Norm.
John Saeli
08-27-2003 18:24:51
Hey Wayne! I had the same problem on a larger Brown. It set up after only a month in the shop. With the clutch depressed I was able to reach in with a bar and pry the clutch loose from the flywheel. Hope this helps.
wayne ragsdale
08-28-2003 03:43:56
 Re: Re: case 1394 clutch wont disengage in reply to John Saeli, 08-27-2003 18:24:51
Hey John, thanks for the reply. I have left the cover off of the housing and when i press the pedal in I can see the pressure plate come off of the clutch. I guess what is confusing me the most is that even with the new clutch it is still doing the same thing it came in the shop for. I cant for the life of me think of anything other than the clutch that would cause this. Transmission?? Do you have any more ideas??
Thanks, Wayne.
John Saeli
08-28-2003 18:34:23
 Re: Re: Re: case 1394 clutch wont disengage in reply to wayne ragsdale, 08-28-2003 03:43:56
Hey Wayne! Is the clutch disc loose from the flywheel when the pressure plate backs off?? The problem I had was that the clutch disc rusted to the flywheel. Pull the disc away from the flywheel.
kyhayman
08-27-2003 18:21:37
If I remember right the throwout bearing holder for the transmission clutch has two slots that the forks go in (the older ones 1210 and 1410 do). A lot of folks get the forks in behind those slots, especially if they try to change the clutch with a splint instead of pulling the engine and clutch assembly.
wayne ragsdale
08-28-2003 03:34:08
 Re: Re: case 1394 clutch wont disengage in reply to kyhayman, 08-27-2003 18:21:37
I have made sure the forks are in the bearing correctly, i left the cover off so I can see what is going on. It is the strangest thing I have ever seen. I can watch the pressure plate move off of the clutch yet it still wont dis-engage. Weird. Thanks for the reply. Any other ideas??
bob
08-28-2003 07:37:02
 Re: Re: Re: case 1394 clutch wont disengage in reply to wayne ragsdale, 08-28-2003 03:34:08
Theres only one way to tell if its the clutch or the trans that's locked up- put it in gear, have someone push on the clutch pedal and hit the starter button briefly or have someone else turn the cranksaft by using a socket or wrench on the center bolt.
If she tries to move, then you know something is still locked up on the clutch, if she doesn't then you know its the trans- maybe its trying to get in two gears at the same time- that will cause the trans to lock up.
wayne ragsdale
08-29-2003 08:26:53
 Re: Re: Re: Re: case 1394 clutch wont disengage in reply to bob, 08-28-2003 07:37:02
That sounds like a good idea, im going to give that a shot. Thansk for the advice!
