Case 430 Diesel pump
Rob Meyer
08-27-2003 11:46:32
I figured it out. Many of you would have done it faster - but I thought I would pass along what was going on. Tractor wouldn't start. I went through the fuel system and cleaned everything - bled everything but just wasn't getting good flow to the injectors. I was just about to say it was the fuel pump and as I was pulling the lines off I noticed that the fuel stop valve on the back was not in the correct position. It seems that the housing on the stop mechanism had broken under the battery tray (out of sight) and allthough you could still pull it to the stop position it would fex badly enough when returning it that it would not reopen the valve to the correct position - resulting in very poor fuel flow. Maybe easy for some but it took me a couple of times looking at it to figure it out.
Oldfarmboy Jim
08-28-2003 14:20:19
 Re: Case 430 Diesel pump in reply to Rob Meyer, 08-27-2003 11:46:32
Good for you! Don't you just feel great when you solve a puzzle like that? Patience, persistance and common sense can save all of us a lot of money that would otherwise go to a repair shop. Jim
