Case 530 CK Timing
Phil (NJ-AZ-SK)
08-27-2003 05:32:33
My Diesel Injector Pump Saga continues.... I have the front Timing Cover off to replace the pump gear Drive Key (sheared) and I can't find/see the MARK on the CAM gear (all that is showing is part of the tooth, integrated water pump.. (I don't want to remove the complete ASSY & Rad/Hyd Pump Etc)
Question: I have set the Crank/Valve timing such that # 1 is at TDC .. Verified by the gauge on the Flywheel and # 4 rocking... If I install the Pump gear such that the gear Pointer(Cam idler)is correct to the Mark on the pump gear.. and then adj Crank timing to 8 deg BTDC to set the PUMP timing (adj pump rotation) will she be correct ?
Comment: The rebuild of my Pump in Canada is more than 2X that of an Exchange Pump from the US... Its harvest time and they up prices....
Thanks for any comment
