Eagle Hitch PTO bracket
Don
08-26-2003 17:46:03
I need a "Mounting Depth Adjusting Screw with PTO shaft guard bracket" for a 1952 D Case. Part number is 4205AA. Can anyone help?
Paul f
08-28-2003 05:45:08
 Re: Eagle Hitch PTO bracket in reply to Don, 08-26-2003 17:46:03
Good Luck they are hard to find. If you want something usable as opposed to correct you can have something fabricated. I had a 3/8inch steel plate made up with holes for the PTO and the four mounting studs, then had 1/2 inch thick ears welded on with a hole through the end of them to use for a three point top link. Welder charged me $25. (I am still welding challenged!!)
