VAC Problem
Gerald
08-26-2003 06:56:47
I'm looking at a 49 VAC to buy. It has a lift with a plow attached. It looks like the lift works off a pump attached at the belt pulley. The problem is, that with the clutch depressed the belt pulley does not always stop and still seems under power as if still engaged. It is erratic though and sometimes when depressing the clutch it will stop so you can put it in gear.As you can imagine this causes a problem with getting it into gear. The seller had to grind the gears to bring things to a halt. He was not able to explain it. "I'm not a case man, I don't know how this works". Anyone familiar with this system? Is there supposed to be a separate throwout for this or is there some throw-out bearing that is not working properly? Would appreciate any comments. If it were to need some "inner work", how big a job would that be?
Minn.Norske
08-26-2003 19:04:45
 Re: VAC Problem in reply to Gerald, 08-26-2003 06:56:47
I also have a Vac it has the hydraulic pump on the engine. But were the pulley goes in the side of the tractor look for some set screws lossen them up then you can slide the pulley ether in or out not sure that will disengage the pulley. Good Luck
wheat straw
08-26-2003 18:35:34
Gerald, Sounds like a clutch problem to me. Even If you buy it and fix the clutch you may want to take the pully off and store it in the shed untill you need to use it. It will act like a flywheel and take a few seconds to coast down. Seconds can seem like forever when your waiting to shift. It is on a tappered shaft and can be a bit tough to get off. Just take the nut off and run it. It will decide to come loose at some point and you can put it on when you go to use the belt.
If you get it, they are nice little tractor. Have fun
Wheat Straw
C. Amick
08-26-2003 14:25:58
There is probably something inside the clutch assembly that is worn and not allowing the clutch to disengage. Is there any adjustment left in the linkage rod? I think it would need to be shortened. If you think the clutch plate could be stuck, with the tractor running and in 4th. gear, hold the brakes and see if you can make the clutch slip.
Gerald
08-29-2003 13:12:21
 Re: Re: VAC Problem in reply to C. Amick, 08-26-2003 14:25:58
C. Amick-- I followed your advice. The linkage had about 3/16" left of the thread. Turned it as far as it would go and reconnected. Wulla! the clutch now disengages enough to shift without grinding the gears. Probably will need clutch work though, Huh? Sure is a nice runner and a cute little tractor. I drive it home Sunday, found it just about 14 miles from my home. I'm wondering about the make of the plow. The only paint left on it is a green furrow wheel. How can you tell? Thanks for the pointer on the shifting problem.
C. Amick
08-29-2003 13:37:20
 Re: Re: Re: VAC Problem in reply to Gerald, 08-29-2003 13:12:21
Yes, it will probably need the clutch plate replaced or get it re-lined. Case plows were painted green. Is it a tractor mounted plow or a trail type plow on wheels? I have a set of double 14-inch Case trail plows.
gerald kern
08-29-2003 18:31:17
 Re: Re: Re: Re: VAC Problem in reply to C. Amick, 08-29-2003 13:37:20
The plow is mounted on the tractor and makes a slick-looking rig. If Case plows were painted green, it is probably a Case then. I could have gotten a cultivator with it as well, but have no need of or place for it. Anyone else interested? Minnesota.
Gerald
08-26-2003 15:38:59
Won't have a chance to see it for a few days, but will definitely try out your suggestions. Didn"t notice is there was further travel on clutch adjustment, but will chek that out--possibly as a first thing to try. Thanks for the suggestions.
Mike
08-26-2003 07:50:49
sounds like maybe the clutch isn't disengaging. the pulley will not stop instantly when the clutch is depressed, it will "roll" to a stop. If you depress the clutch and wait for maybe a minute, does the pulley stop turning. if not, then the clutch isn't disengaging. It shouldn't take but a few seconds for the pulley to stop.
Gerald
08-26-2003 11:42:47
 Re: Re: VAC Problem in reply to Mike, 08-26-2003 07:50:49
No, the pulley does not stop no matter how long you hold the clutch pedal in. After he ran it for awhile, it seems that he could shift--he demonstrated that all the gears worked.(As I stated in my other posting, it seemed erratic)Holding something against the pulley with the clutch depressed would not stop it either. What did stop it was him grinding the gears and finally getting it in a gear. Then the pulley stopped and the tractor would not move until the clutch was let out quite a ways (that seemed normal).
